I read that the human range is commonly given as 20Hz to 20,000 Hz. But GSM channels are carrier frequencies of 200 kHz bandwidth. Is that because of SMS part?
It seems for voice 20kHz must be enough. Why 200kHz?
You've misunderstood the answer to your previous question. https://electronics.stackexchange.com/questions/166056/how-does-a-base-station-provide-multiple-channels-without-any-interference
It's not tranmitting analog voice. It's transmitting digital data. TDMA is used to share one 200kHz channel among a large number of voice calls. Each voice call is encoded with the AMR codec and ends up as about 10kbit/sec.
  • \$\begingroup\$ i know it is digital. so the bandwidth increases with A/D conversion even though there is speech coding? \$\endgroup\$
    – user16307
    Apr 22, 2015 at 13:26
  • \$\begingroup\$ @user16307: try sending 20kbit binary data with 20khz bandwidth... \$\endgroup\$
    – PlasmaHH
    Apr 22, 2015 at 13:34
  • \$\begingroup\$ @PlasmaHH do you have formulation for this? am a bit newbie \$\endgroup\$
    – user16307
    Apr 22, 2015 at 13:36
  • \$\begingroup\$ @user16307: no, I do not have a formula for trying to send 20kbit binary data over 20khz bandwidth... \$\endgroup\$
    – PlasmaHH
    Apr 22, 2015 at 13:37
    \$\begingroup\$ Actually, the voice channels are band limited to ~300Hz-4kHz, then encoded using an AMR codec which gives about 12kb/s output. Each channel in a TDMA frame has about ~13kb/s throughput, so is large enough to handle the encoded voice. That encoded data is then packed into a streamwith training patterns, guard bits and other overhead giving about 270kb/s total in a TDMA frame (8 channels). \$\endgroup\$ Apr 22, 2015 at 13:48
