I need to run 5 differnet rgb LEDs from a microcontroller. All the LEDs will be producing the same color so there will only be 3 separate PWMs (1 for each channel of rgb.) My problem is most microcontrollers can't handle this load. What's the best way to handle this?
I was wondering if there is a microcontroller chip/board that can handle 3 separate PWM's outputting from 15 pins. If possible I'd rather not have to use a PWM Driver as this would increase the complexity of my design.
Bonus points if you guys know of a board that's compact.
