... but it runs on Discovery F3 board (exact same MCU). BOOT0=Lo, NRST=Hi
The logfile generated when I try to upload code is as follows:
Thu Apr 23, 2015 09:56:23: Loaded macro file: C:\Program Files\IAR
Systems\Embedded Workbench 7.0\arm\config\debugger\ST\STM32F3xx.dmac
7.0\arm\config\flashloader\ST\FlashSTM32F3xx.mac Thu Apr 23, 2015 09:56:25: ST-Link firmware too old Thu Apr 23, 2015 09:56:25:
Connected to ST-Link/V2 Firmware V2.J16.S4 (Probe no: 2798FD0D) Thu Apr 23, 2015 09:56:25:
Selecting SWD as current target interface. Thu Apr 23, 2015 09:56:25:
Thu Apr 23, 2015 09:56:25: Initial reset was performed Thu Apr 23, 2015 09:56:25:
Hardware watchdog Thu Apr 23, 2015 09:56:25:
(15.29 Kbytes/sec) Thu Apr 23, 2015 09:56:25:
C:\Program Files\IAR Systems\Embedded Workbench 7.0\arm\config\flashloader\ST\FlashSTM32F3xxRAM32K.out Thu Apr 23, 2015 09:56:25:
file: C:\Program Files\IAR Systems\Embedded Workbench
7.0\arm\config\flashloader\ST\FlashSTM32F3xx.mac Thu Apr 23, 2015 09:56:27:
to flash memory.Hardware reset with strategy 0 was performed-I- execUserFlashInit! Thu Apr 23, 2015 09:56:25:
-I-736 bytes downloadedLoaded debugee:Target reset Thu Apr 23, 2015 09:56:27:
C:\Users\dbruere\Documents\SoS\Debug\Exe\SoS.outUnloaded macroDownloaded
  • \$\begingroup\$ Can you provide more information about the hardware? What are the differences between your prototype board and the STM32F3Discovery? \$\endgroup\$
    – davidrojas
    Apr 23, 2015 at 12:01
  • \$\begingroup\$ The Discovery has a built in ST-Link, whereas I use an external ST-Link programmer. All my I/O is the same. Otherwise it's just a severely cut down version of the Discovery F3 \$\endgroup\$ Apr 23, 2015 at 12:08
    \$\begingroup\$ I'm voting to close this question because its way to underspecced to generate a meaningful answer. \$\endgroup\$ Apr 23, 2015 at 12:31
  • \$\begingroup\$ Probably, but I cannot think of any more specific questions - just wondering whether anyone else has had this problem \$\endgroup\$ Apr 23, 2015 at 12:36
  • \$\begingroup\$ The uploaded code seems OK (I can read it back from the MCU), but there may be some kind of difference in addressing when using Discovery? \$\endgroup\$ Apr 23, 2015 at 12:51
The answer appears to be that Discovery F3 provides an external 8MHz clock. My external clock is 16MHz, so I need to alter a divider in system_stm32f30x.c or alternatively use the internal HSI clock
