In VHDL I can write (0 downto 1)
and will generate a Vector with 0 elements.
I want to do this to "rightalign" a field in a union, if needed. Samplecode:
module example #(int ITEMS=3)(output logic[4:0] result);
union {
logic [4:0] result;
struct {
logic systemstatus;
logic [4-1-ITEMS-1:0] padding;
logic [ITEMS-1:0] itemStatus;
} bitfield;
} myStruct;
endmodule;
I want to generate a struct that looks roughly like this:
systemstatus | 0padder | item3 | item2 | item1 //ITEMS==3
systemstatus | item4 | item3 | item2 | item1 //ITEMS==4
As you can see the padding field disappears for 4 items. However the code above will not do what I want in system verilog since instead of creating a vector with 0 elements, I will always create a vector with at least one element ([0:0]
), and when the expression becomes negative ([-1:0]]
) I will create a vector with two elements.
Is there a way to let padding
"decay/degenerate" to an empty vector? I know I could make myStruct.bitfield.itemStatus
simply always the right size and always access a subvector. But the point is to do the magic once in the struct and not worry about it anymore in the rest of the code.
