I bought a mcp73812 charging ic from digikey and I found a circuit online. I don't know much about electronics but I feel like there are issues with the circuit: enter image description here
First of all it says the green led is powered when the battery is fully charged, but I see nothing controlling it, just goes straight to ground. Second of all I was going through the datasheet and found that when pin 1 is high the chip will charge and when low it won't charge. So in the circuit it's tied straight to 5v, does this mean that it will not stop charging until pin 1 is low? If so how do I do this because I don't want to stand by the battery until it's done charging? And lastly it looks like a pretty simple circuit for charging a battery. Will this circuit safely charge the battery? Thank.
I'm using 1000 mah 3.7v lipo battery
IC datasheet
The green LED (D3) shares a current-limiting resistor with the red LED (D2) and the transistor (Q1). When charging is occurring, about 400 mA is flowing through D1 and/or Q1, which turns on the red LED. Since a red LED has a lower forward voltage drop than a green LED, this effectively keeps the green LED from lighting until the red LED is turned off. This occurs when the charge current through D1/Q1 drops to "almost zero when the cycle completes".
No, the IC will stop the charging on its own; you don't need to bring pin 1 low. Pin 1 is there in case you wanted to inhibit charging for some reason.
I don't see why not. I assume this is from the manufacturer's application notes, and they wouldn't want to present their product in anything other than the best possible light.
  • \$\begingroup\$ @Dave Section 4.6 of the datasheet seems to disagree with your comment about charge termination. Maybe I misunderstood something, can you confirm how that mechanism works? \$\endgroup\$ Commented Apr 25, 2015 at 4:19
  • \$\begingroup\$ @RogerRowland - 6.1.1.5 tells it all! The CE pin can be used to inhibit a charge and initiate a charge. high enables, low disables Or terminates a charge. It looks like you are correct, this device does not terminate charge on its own wi \$\endgroup\$
    – Filek
    Commented Apr 25, 2015 at 6:12
  • \$\begingroup\$ However, in the second, and last stage of charging, the constant voltage stage, won't the current eventually reach zero as the battery saturates at 4.2 volts? \$\endgroup\$
    – Filek
    Commented Apr 25, 2015 at 6:24
  • \$\begingroup\$ I don't have 1uf capacitors for the circuit so I was wondering if 2.2uf capacitors would work? Or putting 2 .47uf capacitors in parallel? \$\endgroup\$
    – Trevor
    Commented Apr 27, 2015 at 21:35
  • \$\begingroup\$ 2.2 uF should be fine. \$\endgroup\$
    – Dave Tweed
    Commented Apr 27, 2015 at 22:17
