I have to do a instantation of several components
I suppose the code for this instantation would be something like this:
componentA: componentB port map(
output_ca => input_cb
componentA: componentC port map(
output_ca => input_cc
But I know that part of the code before is wrong, because 'ouput_ca' has 6 bits and input_cb, and input_cc has only 3 bits every one of them. How would be written this code in a good way? Thank you so much for your help.
You must use some signals, you can't map straight from one pin to another (I'm also using direct instantiation to avoid creating component declarations - see also my answer here):
signal aout : std_logic_vector(5 downto 0);
A: entity work.componentA port map(
    output_pin => aout
B: entity work.componentB port map(
    input_pin => aout(5 downto 3)
C: entity work.componentC port map(
    input_pin => aout(2 downto 0)
Aside
You seem to be confused in your instantiation syntax. You wrote:
componentA:componentB port map (...
implying that componentA connects to component B.
What is actually being said is
individual_name_of_component: name_of_entity
So you pick an entity which you are instantiating on the right of the : and give it a name on the left.
  • \$\begingroup\$ Cool, I didn't know about direct instantiation. I always hated keeping component declarations in sync. \$\endgroup\$
    – ajs410
    Jul 12, 2011 at 18:09
