I am trying to create a string with characters outside the ASCII printable range. I am using an STM32 microcontroller using the µVision IDE with the Keil compiler. The documentation allows various escape sequences, including one for "ASCII code in hexadecimal." When I just want one character there is no problem, but if I want to put other numbers in the same string after the character, I start getting issues.
This works.
char myString[10] = "\x06";//(It gives me 0x06,0x00,...,0x00)
This doesn't. (It gives me 0x60
char myString[10] = "\x060";//(It gives me 0x60,0x00,...,0x00)
The more characters (0-F) in the same continuity that keep getting appended as hexadecimal digits of the same number (it will even throw a warning that it is out of range if the number gets too big). Is there some way around this? Might this be a compiler issue?
If you are asking how to terminate a hex escape sequence when followed by a character which is a hex digit, here is a way
"\x06""0"
Use two double-quotes.
Otherwise, a hex escape sequence will use up all consecutive hex digits that follow.
When you initialize a string like that, you are specifying one character at a time. One character can only hold a value between 0 and 255. If you want to fill more bytes of your string, just specify more characters in the initializer:
char myString[4] = "\x06\x60\x44";
Note that unspecified characters are not guaranteed to be filled with 0's, although one 0 will be placed at the end of whatever you specify as the initializer:
char string2[8] = "test";
Five characters will be initialized, characters 6 through 7 might contain garbage.
    \$\begingroup\$ It would be more accurate to say that a string literal specifies one char at a time. The OP did not say what encoding he's using, but in some encodings, there can be more than one char per character. \$\endgroup\$ – Solomon Slow Apr 27 '15 at 20:32
