I would like to transform a signal that has fluctuations between 1.8-1.9V (for example) to be in the range of -1V to 1V. Essentially, run it through a linear transformation [ \$y'= (y-a) \cdot b\$ ] What is the easiest way to accomplish this with standard op amps, such that a and b are tunable (say, with a potentiometer)?
I've used these two circuits in several different applications:
Inverting with variable input impedance dependent on Gain. No interaction between Gain and Offset.
Non-inverting with high input impedance. Gain is slightly dependent on the Offset setting.
This doesn't answer the entire question - I'm leaving some engineering work for you to do - but it should get you started.
  • \$\begingroup\$ @ShayOhayon: I reread your example and realized that both circuits could actually work, so I removed the note saying that only one could. \$\endgroup\$
    – AaronD
    Apr 28, 2015 at 14:44
