I'll try explain everything as clearly as I can as it's slightly complicated. I really need help as I'm quite new to this kind of experiment and work so any help would be extremely appreciated.
I did some LIV tests with some LED lights and gathered some results. However I'm not an expert and this is just lab work so I'm not sure I understand what all the data that the machine retrieved means.
My final goal was to plot the External Quantum Efficiency (EQE) against the injected current into the device, where I gradually increase the injected current. Therefore I needed to find the Light output power (LOP) and divide it with the input power to give the EQE, as
EQE = Output Power / Input Power
Look at the first file which consist of all the data retrieved for the first LED: SPREADSHEET 1 [http://imgur.com/bpoadSP][1]
NOTE: Spreadsheets can be zoomed in by clicking on the picture!
I'm not sure what all this means but I know that the column under "PS Amps" is the supplied current, the one under "PS Volts" is the supplied voltage, and I assumed under "Watts" is the output power. Therefore I found the input power to be simply the supplied current x supplied voltage
. This resulting value is higher than the output power column so I was quite confident that the the column under "Watts" in that spreadsheet is the output power.
So simply I divided each element of that row of output power under watts with each element of the total input power. This gave me the corresponding EQE for each row as the injected current increases.
However I'm still confused if I'm doing this right as there is a problem - in the second spreadsheet here: SPREADSHEET 2 [http://imgur.com/yBMJwAO][2]
As you can see in this second spreadsheet I'm using the same example of test data for the same LED, after 0.001amps in the current row its the exact same data as spread sheet 1. Here I simply listed the supplied voltage, current, and the light output power together for easier access.
However the data above 0.001amps where the LOP is all listed wrongly as "1" (as a place holder as remember I don't know how to find output power with this new data), was retrieved as I was asked to take measurements without using the LIV test system as the machine couldn't take readings with such low current. These sets of reading I only got the supplied current and voltage like shown in the diagram, and I've reassured with a lab partner that is all we were supposed to take.
How am I supposed to find the total Light output power like I have with the data in spreadsheet 1 then? In spread sheet 1 all the data is given in such detail including the watts column which as I have mentioned I think is the light output power as its lower than the supplied I x supplied V
. Is there a way to calculate the light output power so that I can find the EQE for the recordings above 0.001amps from the second spreadsheet?
To summarise in short:
1) Need to retrieve data of LEDs to plot their EQE (external quantum efficiency) against the injected current.
1) With the data in Spreadsheet 1 I retrieved readings of the output power while increasing injected current. Supplied voltage is also listed, so I could do injected current * supplied voltage = input power
, then assume the colum under 'watts' is the output power as it was a reading from the test system, and therefore do output power / input power
to find the EQE as I have learned.
3) However more readings of injected current under 0.001amps had to be taken with another machine, and the data is shown in Spreadsheet 2 but does not include LOP or a "Watts" column so I don't know how to find output power. I still have input power as I have both supplied current and supplied voltage there.
Is there something I don't know about the data in spreadsheet 1 that can help me find the light output power in spreadsheet 2 with the extra readings? Or am I calculating everything wrong and the light output power is given in another way? Please help as I'm not sure what the data all means in the first spreadsheet and I'm struggling to find the way to find LOP in the second.
[1]: Spreadsheet 1 - DATA of LED [2]: Spreadsheet 2 - DATA of LED with Extra Readings Under 0.001amps
