I am doing a project on SMS sending through GSM using SIM 900 module and 8051.
My code is:
#include<reg51.h>
unsigned char *command = "AT";
unsigned char *echo = "ATE0";
unsigned char *msgConfig = "AT+CMGF=1";
unsigned char *number = "AT+CMGS=\"8283******\"";
unsigned char *message = "hello";
unsigned char *CTRLZ = 0x1A;
void serial_init(void);
void serial(unsigned char);
void puts(unsigned char *p );
void delay(void);
void main()
serial_init();
puts(command);
delay(); // delay of approx 1 sec
puts(echo);
delay();
puts(msgConfig);
delay();
puts(number);
delay();
puts(message);
delay();
puts(CTRLZ);
while(1);
TMOD=0x20; //timer 1, mode 2(8-bit autoreload) to set baud rate
TH1=0xFD; //-3 to TH1 for 9600 baud rate
SCON=0x50; // 8 bit txion, 1 start 1 stop bit, REN enable for both txfr and rxve
TR1=1; // start timer
void puts(char *p)
char *temp = p; /*temp pointer so that the actual pointer is not displaced */
while(*temp != 0x00)
serial(*temp);
temp++;
void serial(unsigned char x)
SBUF=x;
while(TI==0);
TI=0;
void delay(void) // delay for approx 1 sec
int i;
TMOD=0x01; // timer 0 in mode 1
for(i=0;i<142;i++)
TL0=0x00; // starting value from 0
TH0=0x00;
TR0=1; // sart timer
while(TF0==0); // polling TF flag for high
TR0=0; // stop timer
TF0=0; // clear flag TF0
The problem here is that the SMS has not been not sent by the GSM module.
When I use the calling function by replacing the AT commands, then calling works but SMS does not. I think I am wrong in sending AT commands for SMS.
"\x1a"
. \$\endgroup\$
