Is there a way to communicate between arduino device and the android device through the bluetooth?
I know it is and for that is used some pfodApp, but what if I want to make my own application, without a need of standalone pfodApp. Do you know if there is anything like pfod library for Java/Android? Which would allow me to pair and communicate with the arduino?
Check this: pfodApp
  • \$\begingroup\$ If you want native android libraries, it's simply serial over bluetooth. Android supports the pairing like normal, the rest is a standard Bluetooth serial library. Google "Arduino android bluetooth library" for hundreds of examples. \$\endgroup\$
    – Passerby
    Commented Apr 29, 2015 at 18:05
  • \$\begingroup\$ Super, thank you. I thought that it requires something special, since it is arduino... \$\endgroup\$ Commented Apr 29, 2015 at 18:29
The only thing that pdof does is a set of standard protocols of communication in a neat package. Depending on the complexity of your project, creating your own serial message might be easier or quicker.
