I'm just beginning with circuits, so pardon if this is elementary, but I couldn't figure it out.
I'm building a speaker joining several circuit boards together:
  • a trinket pro
  • a class d amp
  • an FM radio chip.
The trinket controls the class d amp and FM radio via I2C bus(sda/scl).
All these boards need connections to 5V power and ground. On a breadboard this is easy.
Currently, I'm making a rats nest of wires where I twist 2 or 3 wires into one and then solder them.
However, what is the best practice to create power rails and ground rails multiple chips can plug into? Should I be using a perfboard or other tool?
You need to use a Prototyping Board. Most of them have pre-drilled holes and pre-existing copper tracks.
There are different kinds, it is often just down to your personal preference which one you use.
This one is useful for transferring the layout directly from a breadboard:
This one, "Stripboard", is useful when you have several buses, such as multiple power rails, or signals like clocks, data buses, etc:
There are some other ones where there are no copper tracks on the underneath, just single pads on each hole which enable soldering; a wire is wrapped on pins underneath, and a route created directly to the destination, then the wire soldered:
Other boards not shown might include PCI boards etc for direct insertion into expansion slots on PC motherboards, and so on. There are also some meant for small-pitch surface-mount chips.
