I did many research but couldn't find out what the problem it is. Actually my code as below. I am trying to implement a code in C with XC8 compiler.
To enable a sentence on the LCD of the board while RB6 button is pressed. I enable INCTONbits.GIE = 1 and INTCONbits.RBIE = 1 and INTCONbits.RBIF = 0.
Inside of interrupt, the displaySentence() function is entered to infinity loop to see result. I checked all answers related with interrupt in here but didn't help my problem. What can be problem for RB7-4 interrupt, I am working on PIC18f8722.
void displaySentence();
void initialize();
void interrupt  RBINT_ISR(void){
    INTCONbits.GIE = 0;
 __delay_ms(10);
    while(1){
        displaySentence();
    INTCONbits.RBIF = 0;
    INTCONbits.RBIE = 1;
    INTCONbits.GIE = 1;
void main(void)
    __delay_ms(15);
    __delay_ms(15);
    __delay_ms(15);
    __delay_ms(15);
    InitLCD();          // Initialize LCD in 4bit mode
    ClearLCDScreen();  // Clear LCD screen
    initialize();
    while(1);
void initialize(){
    TRISB = 0x40;
    PORTB = 0x00;
    // | GIE/GIEH | PEIE/GIEL | TMR0IE  | INT0IE | RBIE | TMR0IF | INT0IF | RBIF
    // |   1      |    0      |  0      |  0     |   1  |   0    |    0   |  0
    INTCONbits.GIE = 1;
void displaySentence(){
    WriteCommandToLCD(0x80);
    WriteStringToLCD("Interrupt");
    WriteCommandToLCD(0xC0);
    WriteStringToLCD("is working");
  • \$\begingroup\$ Does the LCD work to display strings from main()? How are you triggering the PortB interrupt? How are your PortB pins connected? \$\endgroup\$ – brhans May 1 '15 at 13:49
  • \$\begingroup\$ Yes LCD works correctly inside the main,I need to control RB6 button with PORTB change interrupt. I need to enable pull-up. \$\endgroup\$ – Alihuseyn May 1 '15 at 14:05
    \$\begingroup\$ Have you enabled PortB pullups somewhere or do you have external pullup resistors? I don't see anything like a "INTCON2bits.RBPU = 0;" anywhere in your code to enable the internal pullups. \$\endgroup\$ – brhans May 1 '15 at 14:15
  • \$\begingroup\$ I didn't use "INTCON2bits.RBPU = 0;" but while using it directly goes to interrupt.It may be due to external pull up resistors. \$\endgroup\$ – Alihuseyn May 1 '15 at 15:03
Thanks @brhans for your answer I did as you said. I disabled INTCON2bits.RBPU = 0 and it worked for me.
