I'm new to uC development and have been fooling around with the PIC series for about 6 months now. I recently started working with the PIC32 and Microchip's XC32 C++ compiler. I don't know if I have a fundamental misunderstanding of how the WDT works on the PIC series, or if there is some caveat of which I am unaware, however I have some code that I think should light an LED on RA0, then turn it off and after 512ms the WDT should reset the uC and the process should start over. What is actually happening is that the LED comes on momentarily, then goes off and never turns back on. I don't know if this means the WDT is incorrectly configured or what. Here is my code:
#include <xc.h>
#define LED _LATA0
int main(int argc, char** argv) {
WDTCONbits.WDTPS = 0b1001; //512ms postscaler
WDTCONbits.WDTCLR = 1; // feed the watchdog
WDTCONbits.ON = 1; // enable the watchdog
TRISAbits.TRISA0 = 0; //output on RA0
ANSELAbits.ANSA0 = 0; // digital only
LED = 1; //led on
int i = 100000;
while(i--);
LED = 0; // led off
while(1); // hang up and let WDT reset us
return 0;
What part of successfully using the WDT am I missing?
