We must move from WM8731SEFL to WM8731CSEFL, as the original part is obsolete.
I am advised the only difference is the "introduction of copper bond wires".
Order Code WM8731LSEFL and WM8731LSELF/R changed to WM8731CLSEFL and WM8731CLSEFL/R to reflect change to copper wire bonding.
What is a copper bond wire? Does it refer to the interconnects, the solder pads or something else? Could the change affect RF emissions?
Bond wires connect the external pads to the chip die itself. Traditionally they're gold. Presumably some new manufacturing technique allows the use of cheaper copper. I doubt this will be externally detectable; maybe it makes some difference to the expected lifetime and corrosion resistance of the chip.
  • \$\begingroup\$ Thanks, so most likely RF emissions remain unchanged? \$\endgroup\$
    – SeanJ
    May 5, 2015 at 8:28
    \$\begingroup\$ I would assume so - the wires are tiny. \$\endgroup\$
    – pjc50
    May 5, 2015 at 8:32
