I am designing a PCB in EAGLE and I want to use an 7815 TO-220 voltage regulator. When I check the top or bottom layer mask of my PCB I can see that there is a hole (with no copper I think) behind the voltage regulator. Is this normal or I am using the wrong model?enter image description here
    \$\begingroup\$ If the footprint is using an unplated hole for the TO-220 it might increase your manufacturing costs (if it's the only unplated hole). Looks like your mounting holes are also unplated. \$\endgroup\$ May 5, 2015 at 15:26
8
It's hard to tell from the spacing but that hole is likely there so you can screw the regulator to the board, or more likely mechanically attach a heatsink.
You can see an example:
If there was copper you'd run the risk of connecting the tab to a trace or an internal plane. This wouldn't work so well if your internal layer contained a power plane.
You should be able to find a vertical part in Eagle if you prefer the voltage regulator to remain upright.
That is the normal mounting hole for a TO-220 package when mounted "lying down" on the board. If you are using a small heatsink, it would be placed between the regulator and board, and held in place, and in good contact with the regulator, by a screw through that hole.
