I am looking for a Zero Insertion Force (ZIF) socket with 0.1" between the two rows. The socket is to accept a DIP header like this:
So one side of the header would go into the ZIF socket, the other side is soldered to a PCB that is being tested.
The problem is that all the ZIF sockets I have found are similar to the green one below. They have 0.1" spacing between pins, but the two rows are at least 0.3" apart (they are all made for DIP package chips that are 0.3" across or more)
Has anyone used or seen or have any ideas on a ZIF connector that would fit a DIP header/connector with 0.1" spacing between the two rows?
