I am working through a paper that discusses the design of a multi-level inverter to connect photovoltaic arrays to the grid. It uses 4 PV modules (only two are shown in the design image below, but it is expandable) along with an H-bridge to produce 31 voltage levels. These are used to produce a modified sine wave with low THD: Proposed inverter design
The scheme for switching Q1 - Q4 uses a reference voltage: V_ref(t) = V_max*sin(wt + delta_ref) enter image description here
The authors given equations for calculating the switch signals, which include "mod 2": Switching equations for Q1 - Q4
I am aware of the usual meaning of "m mod n" as "the remainder left over when m is divided by n". This doesn't seem to work here at all!
Can anybody tell me how the given equations are able to generate the switching signals?: Switching signal graphs
  • \$\begingroup\$ Modulo 2 is the remainder when an integer is divide by 2. For example 7 modulo 2 = 1, since 7/2 = 3 remainder 1. Modulo 2 is used in digital systems because dividing any positive integer by 2 will give a remainder of either 1 or zero \$\endgroup\$ – Chu May 7 '15 at 7:35
  • \$\begingroup\$ Can you give a link to the paper, so we can get a bit more context around the equations? (In particular what the function $$V_{ref}$$ does.) \$\endgroup\$ – Li-aung Yip May 7 '15 at 8:14
  • \$\begingroup\$ Here is the paper, but it is behind a pay wall (perhaps available through your own institution): link. V_ref is a reference sine wave with the same frequency as the desired output AC voltage. I understand the usual remainder usage of modulus, but in this case V_ref is not an integer. It also may never get above 1, depending on the chosen value of V_max. \$\endgroup\$ – DFisher May 7 '15 at 15:31
It's the modulus of the value with 2. It's used to isolate the individual quantization bits in the digital representation of the wave.
  • \$\begingroup\$ I'm not sure what you mean. How does it work to generate the switching signals in this case? \$\endgroup\$ – DFisher May 13 '15 at 18:14
  • \$\begingroup\$ The level modules act as a DAC in order to generate the sine wave. \$\endgroup\$ – Ignacio Vazquez-Abrams May 13 '15 at 22:17
  • \$\begingroup\$ I see a bit better now. For a sinusoidal V_ref (expressed as floating point value), simply taking V_ref mod 2 does not result in a nice 0,1,0,1,... sequence. I'm able to get something by scaling V_ref to +/- 15 and rounding it to the nearest integer value. That way, V_ref is an integer between -15 and +15. Now when I take V_ref mod 2 the value is always the 0 or 1 I want. These are then used for the switching values. Thanks! \$\endgroup\$ – DFisher May 14 '15 at 0:42
