I recently bought some IC's with 8 and 16 pins. I was used to work with bigger ones, so now I cant test them in the breadboard without soldering an individual wire to each pin (which would probably destroy the IC). I thought about sockets, but it doesn't make the distance between pins bigger.
Is there any device I can use to connect the small IC's to the breadboard?
Thank you for your help.
