For at least some STM32F4 MCUs, push-pull + pull-up/pull-down is a valid GPIO configuration, but what would you ever use it for, and why? I assume there's some saner reason than "I just really felt I needed that juicy extra 100µA of wasted current per pin"...
The configuration is listed in section 8.3 of the reference manual, on page 269: enter image description here enter image description here
    \$\begingroup\$ Making such strange combinations illegal would be a waste of silicon, and even if no-one can come up with valid usecase now that doesn't mean there can't be one found tomorrow. So making such configurations legal seems the logical choice to me. \$\endgroup\$ May 9, 2015 at 7:32
Basically the chart shows that the PUPDR bits control the pull-up and pull-down connections independent of the OTYPER bit that switches between push-pull and open drain.
Probably you would not typically set PUPDR to anything but 00 when using the push-pull configuration.
One situation where you might do so is if you were going to switch the pin between output and input functions. You might want the pull-up or pull-down to be configured before you switch to input mode to avoid the input ever being in a truly floating state.
  • \$\begingroup\$ There's also an analog mode (MODER=11,OTYPER=x), which is only defined for PUPDR=00, leaving the combinations with other PUPDR values reserved. Does this explanation still make sense? (ie. if the weird configuration is for convenience, why doesn't the analog mode have pull-up/pull-down options or have PUPDR=xx?) \$\endgroup\$ May 9, 2015 at 5:44
  • \$\begingroup\$ @AleksiTorhamo, You should generally not use any mode described as "reserved". That means that the behavior in the current product is undefined, but it might be used as a useful mode in a future version of the product. Since you don't know what the behavior will be in the future product, it's safest to avoid ever setting that combination of bits. \$\endgroup\$
    – The Photon
    Jun 15, 2015 at 16:30
If, for some reason you decide to disconnect PP but leave PD, you won't have glitches while switching.
