can I use a 5% tolerance resistor instead of a 10% tolerance resistor? It is for an organ from the 60's. All resistors stated in Schematics are 10% 1/2 watt. But I can't find a 6.8k 1/2watt 10% tolerance resistor anywhere. All the resistors in the organ are carbon based.
  • \$\begingroup\$ Usually. But we'd need a schematic to be certain. \$\endgroup\$ – Ignacio Vazquez-Abrams May 9 '15 at 18:30
  • 6
    \$\begingroup\$ I can't think of any reason why 5% could not be substituted for 10%. \$\endgroup\$ – mkeith May 9 '15 at 18:43
  • \$\begingroup\$ possible duplicate of Can a 10% resistor be used as a 1% resistor? \$\endgroup\$ – user20088 May 9 '15 at 23:55
9
Yes, so long as all the other specifications match.
"10% tolerance" on a component simply means that the actual value of the resistor must be within 10% of the specified value. That is, if you measured the actual resistance of a 6.8kΩ ± 10% resistor with a high-precision ohmmeter, you would measure its value as being somewhere between 6.12kΩ and 7.48kΩ.
As such, a 5% tolerance component will also fit the 10% specification: if the value is within 5%, it will certainly be within 10% as well. The lower tolerance just means that its value will be a more exact fit than the original design required!
| improve this answer | |
Yes, you can, if that is the only difference.
Composition resistors are a bit different from more modern carbon film resistors- they are more tolerant of surges, for example.
Carbon composition:
http://www.apexjr.com/images/APEXJRABCARBONRESISTORS1.jpg
Carbon film:
If the resistors are of the same construction and of the same power rating (and of similar physical size- related to voltage and power rating) they will almost certainly work as well as the original. Voltage rating is not usually an issue on a product like an organ unless the resistor is connected to the mains. The same is true of surge capability (expand that to mains or power supply use). Don't replace a large resistor with a much smaller resistor (physical size) if you don't know the power rating.
Nominally, assuming all other things equal, the answer is yes, as other folks have pointed out.
It is worth noting that the distribution of discretes are 'notched' because of binning.
That is, the value of a 10% resistor will lie in the range \$[-10,-5) \cup (5,10]\%\$ because the 5% (and lower) will have been selected out after manufacturing.
Hence, while extremely unlikely in practice (and certainly if manufactured in the '60s), it is possible that a design may not work to specification if higher tolerance components are used.
  • \$\begingroup\$ I'm not sure this is true. I've had to have had MANY 5% resistors closer than 1% nominal of the years. \$\endgroup\$ – Scott Seidman May 10 '15 at 0:43
  • \$\begingroup\$ @ScottSeidman: My information is a little dated. I am certain that many pre-2000 Monte Carlo simulations on discretes were carried with binned distributions. It is possible for economic reasons that the presumption of binned distribution is not always valid. I was really just pointing out a fact that surprised me when I discovered it first. (Did your resistors come off a roll?) \$\endgroup\$ – copper.hat May 10 '15 at 0:51
  • \$\begingroup\$ often out of bags -- over decades \$\endgroup\$ – Scott Seidman May 10 '15 at 2:23
    \$\begingroup\$ @ScottSeidman: Related electronics.stackexchange.com/questions/157788/…. \$\endgroup\$ – copper.hat May 10 '15 at 2:27
