I am using the LX9 Microboard from AVNET with the Spartan 6 PFPGA. I implement SPI to read from an ADC (ADS7822). I was getting wrong sampled values. When I ched the signals with an oscilloscope, it was not as I expected.
FPGA Clock (system): 100 MHz Divider: 32 SPI Clock (output): 3.125 MHz
So I expect, a 320 ns cycle with 160 ns HIGH time and 160 ns LOW time. From the Simulation I get exactly what i expect. But using an oscilloscope at the PMOD output, I get a clock signal thats not too satisfactory. Also from the ADC datasheet (Pg. 10) the minimum high or low time should be 125 ns when working above 4.74 Vcc. Vcc in my case is 5V.
The high time is 132 ns at 3V level (HIGH) and and 144 ns at 0.8V level (LOW). The clock duration converges at 3.2V level. The expected time is 160 ns and I don't find any reason for the poor clock output.
Below diagram is a screen print of the oscilloscope.
Blue line: CLK Redline: CS
The reason I mark the values at 3V and 0.8V is as per theADC datasheet (Pg. 4) the Vih is from 3 to 5.5V and Vil is from -0.3 to 0.8V.
Please suggest a possible reason for the poor output from the FPGA and how do I improve the clock output?
  • \$\begingroup\$ What specifically is it that appears to be wrong - is the frequency incorrect? Also, what oscope are you using? \$\endgroup\$
    May 11, 2015 at 11:37
    \$\begingroup\$ The output doesn't seem bad. It's probably better in reality than your scope is showing, since the probe is loading the line. What you should check is the period -- measure the distance between two consecutive rising edges. \$\endgroup\$
    – avakar
    May 11, 2015 at 11:39
  • \$\begingroup\$ I am using the PicoScope 3000 series. \$\endgroup\$
    – dDebug
    May 11, 2015 at 11:40
  • \$\begingroup\$ @avakar I understand. But at what point (voltage level) should I measure the distance. Ichoose 3V and 0.8 V for HIGH and LOW. The low and high time also matters. \$\endgroup\$
    – dDebug
    May 11, 2015 at 11:43
  • \$\begingroup\$ Your measurement is not correct. The duty cycle is measured at 50% (=Vdd/2). So measure again at 1.65 Volt, if Vdd is 3.3V. \$\endgroup\$
    – Paebbels
The duty cycle is measured at 50% (\$\frac{1}{2}V_{dd}\$). So measure again at 1.65 Volt, if \$V_{dd}\$ is 3.3V.
The 'real' high and low times:
- above 90% of \$V_{dd}\$ is high
- below 10 % of \$V_{dd}\$ is low
does not matter. If a circuit has special requirements for the clock or data signal, it defines rising and falling time.
Example: \$t_{LH} \le 5\,ns\$
Rise time from low to high (10% to 90%) should be less than 5 ns.
So the circuit can be sure that the signal is risen or fallen after a predefined time and the signal can be sampled by the input logic.
