I am having trouble understanding how this ring modulator works i.e. how it multiplies the input & carrier to give us appropriate output? Any help or guide will bedeeply appreciated.
Reference - http://en.wikipedia.org/wiki/Ring_modulation
\$\begingroup\$ Have you tried reading your linked article's text? \$\endgroup\$ – EM Fields May 13 '15 at 10:35
\$\begingroup\$ Yes I have gone through the explaination they give there but to my mind it's not clear how the bridge is causing the two signals to get multiplied - also, the theory there says that for this part of cycle this is on & so on... but how excatly voltages are getting multiplied - this I AM NOT able to concieve. \$\endgroup\$ – Madhusudana May 13 '15 at 10:39
\$\begingroup\$ They're kind of cheating when they say "multiply" without explaining that when a diode is switched OFF and is, therefore, blocking a signal, that's equivalent to multiplying the signal by zero, and when it's switched ON and the signal is allowed to pass, that's equivalent to multiplying the signal by 1. \$\endgroup\$ – EM Fields May 13 '15 at 10:54
The use of "multiply" in this instance refers to that when a diode is switched OFF and is, therefore, blocking a signal, that's equivalent to multiplying the signal by zero, and when it's switched ON and the signal is allowed to pass, that's equivalent to multiplying the signal by 1.
\$\begingroup\$ Oh! is it that? I thought that two signals are getting algebrically multiplied. Anyway can you give some reference from where I can read how to multiply two signals as it actually happens in amplitude modulation. Thanx! \$\endgroup\$ – Madhusudana May 13 '15 at 11:06
