Some good answers above. But VHDL is also behavioural modelling language. You can use to represent the behaviour of any digital system, arbitary behaviour. It effectively comes into two flavours (all part of the same language), behavioural statements which describe the behaviour of a digital system (complete digital system, components: CPUs, FPGA's, ASICS, CPLDs), and synthesiable parts of the language.
You can describe an entire system using behavioural VHDL and simulate it. You can write test pattens in VHDL. You can create, build the system, test it and verify its behaviour with your behavioural models and test data. I don't say here how you design and build the actual system, it's down to the designer (human being) to do that, in this scenario, the VHDL is an abstract representation of the behaviour. There are behavioural statements (as other posters have indicated) which can not be synthesied into working digital logic, so a synthesis tool can not automatically construct a logic circuit implementation.
The other fundamentally important way VHDL is used is in synthesis and to do this, you have to restrict yourself to a subset of the language. Writing behavioural code which is then synthesized into logic gates (or other logic functions which match your target architecture of the device in which you are going to place the design - FPGA for example).
You can describe the behaviour as a finite state machine in textual written code and have a synthesis tool create the logic circuit for you. (You might do some of the state assignment yourself in the VHDL code). You can write statements such as: A:= B* C + D and the synthesis tool will create a logic design to carry out the multiplication and addition of the integers represented by B,C, D.
You can have models of complex logic functions (complete microprocessors) and connect these components together in VHDL (and then simulate).
So VHDL can model ANY logic function, no matter how simple or how complex. Microprocessors, UARTS, system on chip. But I've never heard of it being used for PCBs, not in an analogue sense. But if you have a complete circuit design containing multiple digital logic chips, including complex functions such as microprocessors then yes, VHDL can model the entire lot and you can carry out simulations of it. You can write high level test data, (also in VHDL) and stimulate your VHDL model of your sytem with it and verify the entire design does what you want it to do.
