I am building a simple circuit that will use a J-K flip flop to enable me to use a momentary switch as a toggle.
The circuit diagram states that a 4027N should be used.
My local supplier has a 4027 in stock.
This is a really basic question I'm sure, but is this the same thing? What does that trailing N in the name mean?
The alternative will be fine.
The trailing letters tend to be manufacturer specific, usually identifying the package (e.g. SOIC, DIP, etc.) or other properties like being lead free, or industrial/automotive/military temperature ranges, etc.
An example is the NXP version of the 4027. They have two:
  • HEF4027BP
  • HEF4027BT
For them, the 'P' one is the DIP package and the 'T' one is the SOIC package. But according to one of their other datasheets (granted for a different part), they use 'N' to signify a DIP package in America. This is probably where the 'N' comes from in that schematic.
You don't think there's any issue here with switch bounce? If the switch does bounce, the clock input may see multiple 0->1 rising edge transitions for a single press of the switch, toggling the output multiple times.
  • \$\begingroup\$ Recommendations for a switch debouncing circuit welcome, Dean. \$\endgroup\$ – Richard Ev May 16 '15 at 16:46
  • \$\begingroup\$ From what I remember Schmitt trigger circuit is often used - or a logic gate which has a schmitt input. And a capacitor is included to remove any spikes caused by the switch. Implementations can also be done with SR latches. Here's a couple of links for you. all-electric.com/schematic/debounce.htm \$\endgroup\$ – Dean May 17 '15 at 19:07
http://www.all-electric.com/schematic/debounce.htm
https://www.google.co.uk/url?sa=t&source=web&cd=1&cad=rja&uact=8&ved=0CB0QFjAA&url=http%3A%2F%2Fwww.eng.utah.edu%2F~cs5780%2Fdebouncing.pdf&ei=FOFYVe2cK4TXU5iMgLAN&usg=AFQjCNEppSfSIc313thRdgXgoWieieFjFw
