I made a custom board based on a PIC16F877 but for now I only soldered the minimum. I installed MPLABX and the XC8 compiler, connected the ICD3 to the board, adapted a "blink" example to RD0 where my LED is, programmed the PIC and ran the program. Nothing has happened.
I removed power to the board and applied 5V (my Vcc) across the R+LED (- to cathode obviously), and it lit up... So I checked the footprint in the datasheet, RD0 is really there and I had little doubt since it's a plug&play CAD component from Modelsource.
So what's wrong then? Programming went fine, here is the log:
(ICD3)
Connecting to MPLAB ICD 3...
Currently loaded firmware on ICD 3
Firmware Suite Version.....01.36.10
Firmware type..............Midrange
Target voltage detected
Target device PIC16F877 found.
Device ID Revision = 6
The following memory area(s) will be programmed:
program memory: start address = 0x0, end address = 0x7ff
configuration memory
Device Erased...
Programming...
Programming/Verify complete
(output)
BUILD SUCCESSFUL (total time: 155ms)
Loading code from C:/Users/[...]/MPLABXProjects/test.X/dist/default/production/test.X.production.hex...
Loading completed
Connecting to programmer...
Programming target...
Programming completed
Running target...
If programming was ok, that means the frequency was set up properly. I'm not sure if it's a software or a hardware mistake, so here is the schematic: enter image description here (bigger) (the jumper is not connected, such that TX and RX are disconnected)
Code:
#define _XTAL_FREQ 20000000
#include <xc.h>
// BEGIN CONFIG
#pragma config FOSC = HS // Oscillator Selection bits (HS oscillator)
#pragma config WDTE = ON // Watchdog Timer Enable bit (WDT enabled)
#pragma config PWRTE = OFF // Power-up Timer Enable bit (PWRT disabled)
#pragma config BOREN = ON // Brown-out Reset Enable bit (BOR enabled)
#pragma config LVP = OFF // Low-Voltage (Single-Supply) In-Circuit Serial Programming Enable bit (RB3 is digital I/O, HV on MCLR must be used for programming)
#pragma config CPD = OFF // Data EEPROM Memory Code Protection bit (Data EEPROM code protection off)
#pragma config WRT = OFF // Flash Program Memory Write Enable bits (Write protection off; all program memory may be written to by EECON control)
#pragma config CP = OFF // Flash Program Memory Code Protection bit (Code protection off)
//END CONFIG
int main()
  TRISDbits.TRISD0 = 0; //RD0 as Output PIN
  while(1)
    RD0 = 1;  // LED ON
    __delay_ms(1000); // 1 Second Delay
    RD0 = 0;  // LED OFF
  return 0;
I have tried debugging it via "Build for debugging Main project" and "Debug main project" but it says "[Programming/Verify complete.] The target device is not ready for debugging. [...]"...
    \$\begingroup\$ #pragma config WDTE = ON Probably not the cause, but the watchdog timer will keep resetting your code periodically. \$\endgroup\$ May 13, 2015 at 19:14
  • \$\begingroup\$ Thanks for the tip. Setting it to OFF didn't solve anything as you suspected though :( \$\endgroup\$
    – user42875
    May 13, 2015 at 19:17
  • \$\begingroup\$ There are multiple pinouts, depending on the package: ww1.microchip.com/downloads/en/DeviceDoc/30292D.pdf - are you sure you have the right one? \$\endgroup\$
    – user17592
    May 13, 2015 at 19:25
    \$\begingroup\$ "If programming was ok, that means the frequency was set up properly." ... I program processors for old legacy boards that do not have an ICD connector using an ICD3 along with a "Universal Programming Module" which has a ZIF socket. No clock source is connected, so I'm pretty sure that programming success does NOT mean your clock source is working. \$\endgroup\$
    – Tut
    May 13, 2015 at 20:07
    \$\begingroup\$ You probably should be asking, "why can't I debug?" If you could debug, you could pause the execution and see where your program is. If you asked why can't I debug, I would guess that something is wrong with your oscillator. \$\endgroup\$
    – Matt
    May 13, 2015 at 22:05
The fact that you can't debug the project is a good indication that your hardware set up or configuration bits are incorrect. Just because you can program the device is no indication that the micro is receiving a valid clock signal. Because your config bits look ok, no clock signal is the most likely problem.
1) What is the connection from the MAX233 to MCLR all about?
I would remove R3 and see what happens.
2) Change your configuration word to disable the watchdog until you have everything sorted out.
  • \$\begingroup\$ It is to be able to reset the micro from the control PC, as designed in electronics.stackexchange.com/questions/163742/… I'll remove that tomorrow, hopefully it's that because I have no other clue :( The WDT is now OFF, I haven't changed it back. \$\endgroup\$
    – user42875
    May 13, 2015 at 21:19
