6
I am looking for .gitignore file for the Lattice Diamond IDE. I've been trying to only add what I need, but it would be nice to have a .gitignore that just ignores all of the automatically generated files for build/documentation/etc. Yes, I could sit down and make one myself, but a ready-made already existing file would be ideal.
The build process that Diamond runs through, plus any IP thats included from their included tools, all generate a lot of files, some necessary, many not. I've not come across a clear definition of what is needed and what is not, nor have I been able to find a boilerplate .gitignore for the IDE.
I debated where to place this question, I apologize if it is off topic here, however electronics SE seemed like a best fit since it involves an FPGA IDE.
EDIT: I would really like an explanation as to why this is being downvoted. If anyone has resources I am missing about what files Diamond generates that are temporary, then by all means please downvote. But I would also appreciate a point in the right direction. I spent a good while searching through Diamond documentation, and would love to be proven as an idiot, so long as it means I get a good answer.
  • \$\begingroup\$ I'm voting to close this question as off-topic because this question is not directly related to electronic design but rather than development tools. \$\endgroup\$ Commented May 22, 2015 at 9:29
    \$\begingroup\$ @ChetanBhargava Thats fine, what SE group would you recommend this question would get posted under? \$\endgroup\$ Commented Aug 19, 2015 at 23:12
  • \$\begingroup\$ I did not down vote though :-) \$\endgroup\$ Commented Aug 20, 2015 at 5:14
    \$\begingroup\$ This seems like a reasonable question to me, I know I have the same issue with Xilinx and someone maintaining a list of ignores is really helpful. \$\endgroup\$
    – Sam
    Commented Aug 20, 2015 at 16:11
8
It took me a few hours of guess and check to figure out what exactly is needed and what isn't. The project I inherited used the project directory as the implementation directory (where it dumps most of the temporary files). See below with what I came up with. Note that this is by no means complete, there are lots of features to Diamond that I am not using, so there may be other files and folders created that I am not aware of; which is why I was asking for something more complete.
This comes with no warranty, and assumes that the implementation directory matches "impl*/" as is the default setting when creating a new project. If I come up with anything else, I will edit this over time to keep it current.
*.html
impl*/
*.xml
.build_status
.run_manager.ini
.recovery
.spread_sheet.ini
.spreadsheet_view.ini
*.dir/
*.log
*.tcl
*.ccl
*.srp
*.dmp
._Real_._Math_.vhd
Edits:
  • 20200505 - Added additional files that I've found were generated and not needing to be tracked in git as of some recent Diamond releases.
A way to figure out the required files is to use the "File"->"Save Project As..." and to specify a new folder where to save it. It look like Diamond then create a minimum of files while still allow to rebuild all the others files.
Then you can choose if you want to track the GUI setting related files or not.
  • \$\begingroup\$ While not entirely true (I just tried it and it brought along the implementation directory with .html files, made sure "copy generated files" was unchecked), this is a fantastic way to get rid of various generated files. Albeit a little roundabout. \$\endgroup\$ Commented Oct 13, 2016 at 20:56
  • \$\begingroup\$ I also just noticed that, while it does copy over .xcf project files, it misses .ddt Diamond Deployment Tool files. \$\endgroup\$ Commented Oct 13, 2016 at 21:03
