Altera Quartus, as most other EDA tools, allows users to use their favorite editor, instead of the built-in editors. For Quartus, this feature can be activated in Tools > Options > Preferred Text Editor.
When I fill in stuff in this dialog, Quartus does not store the data. The old editor is still used, and when I come back to the dialog, the default value is still there ("Quartus II Text Editor" is selected).
Have any of you encountered this? What am I doing wrong?
    \$\begingroup\$ Does anyone know where Quartus stores these settings? (there might be a problem with permissions?) \$\endgroup\$ – Philippe Jul 19 '11 at 13:47
It turns out that things are stored in ${HOME}/.altera.quartus/. This directory was owned by root on my system, probably because I had executed quartus with root privileges before.
I removed the directory and everything was fixed after that.
    \$\begingroup\$ chown user.group -R is usually the solution for this kind of problems. \$\endgroup\$ – Johan Jul 20 '11 at 19:30
  • \$\begingroup\$ @kurtuk the systems has requires a 24 hour delay between posting my own answer and accepting it. It is accepted now. \$\endgroup\$ – Philippe Jul 21 '11 at 19:41
I didn't have a problem setting it to use the PFE text editor and PFE was used when I created a new VHDL file to test it. I then reverted to the standard Quartus II editor.
The Altera forum is the best place for questions like this.
  • \$\begingroup\$ you're probably right about asking this stuff on the Altera Forum. Thanks. \$\endgroup\$ – Philippe Jul 21 '11 at 19:42
