Question: Design a state machine that would output the sequence 0 1 7 1 and then 1 7 1 1 7 1 and so on. A reset will make the machine go to the which outputs 0?
What I've managed to do so far:
Since the sequence has four numbers so we use two Flip Flops. And states would be: 00, 01, 11, 10
And I'm considering "reset" to be an input, so the state table would have 2^3 = 8 rows.
Present St. Input Next St. Output in Dec.
00 0 01 0
00 1 00 0
01 0 10 1
01 1 00 1
10 0 11 7
10 1 00 7
11 0 01 1
11 1 00 1
From this table, I can draw K-Maps to find out simplified equations for D_A and D_B which are going to be the inputs of two D-Type Flip-Flops. But I'm to unable figure out how to display the output?
Should I convert it to binary and use three state machines instead since 7 would be 111 and three flip-flops would be needed to store this value.
Or can I use a ROM if Size 2*3 having two address lines and 3 bit output.And burn 0, 1, 7, 1 at respective locations 00, 01, 10, 11. Or is there a better solutions? Thank you. :')
