I recently purchased addressable RGB LED strips based on the WS2811 chip. These strips have a single data + clock line that uses NRZ style encoding to distinguish between a 1 and 0. The datasheet for the strip can be found at https://www.adafruit.com/datasheets/WS2811.pdf
Since the timing is strict for these strips, I am trying to use assembly code to drive the strip (my first attempt with assembly).
Using Atmega168 @ 16Mhz (1 clock = 62.5ns), I call the following assembly code (which I expect to set the LED color to WHITE).
asm_pin_toggle:
sbi DDRC, 4
;reset the led strip data line ~50us
ldi R19, 255
loop:
    nop
    dec R19
    brne loop
ldi R19, 23 ;loop 24 times - all 1 bits
loop_all_1:
    sbi PORTC,4
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    cbi PORTC, 4
    dec R19
    brne loop_all_1
ret
However when I run this I get the color GREEN. Any ideas what am I doing wrong?
There are many version of the WS2811 timing floating on the internet. The one I have used is
  • T0H - 250ns
  • T0L - 1000ns
  • T1H - 1000ns
  • T1L - 250ns
  • RET - >= 50us
any help will be much appreciated!
  • \$\begingroup\$ Is there a particular reason why you don't want to use the normal C delay macros? \$\endgroup\$ May 16, 2015 at 5:54
  • \$\begingroup\$ @IgnacioVazquez-Abrams No particular reason except I wanted to use this opportunity to learn bit of assemble as well. \$\endgroup\$
    – Ankit
    May 16, 2015 at 6:02
Problem fixed.
I was loading 23 into R19 register(hence the loop was only getting executed 23 times instead of 24).
Fixing that to 24 solved the issue.
