Im trying to make a low power application feeding it from a 9vAC, source, i have been reading that i can use a half wave instead of a full wave rectifier, i already did the circuit and been doing tests
Using the osciloscope you can see the wave forms from the Vin, the output of the diode, and finally the output odf the diode using a Avg sampling, im not sure if this waveform is enough to power a microcontroler using 3.3v im thinking about increasing the Cap value, and see how it modifies the rize, however, my main concern here is, how can i justify to do this instead of a full wave rectifier?, and also how can i make sure i will get the steady, 3.3v with as little noise as possible?
