If I am using a J-K flip-flop, but only need one of the outputs, what should I do with the other?
Leave it disconnected, or tie it high/low (via a resistor?) Why?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityIf I am using a J-K flip-flop, but only need one of the outputs, what should I do with the other?
If it is an output, simply leave it unconnected.
If you try to connect it to a power rail directly, it will just short out the supply when the flip flop output is driving to the opposite rail. If you connect via a resistor, it will just waste power - there will be a voltage drop across the resistor when the output is opposite from the resistor's bias supply rail.
Generally you never tie unconnected outputs high/low. Only unconnected inputs.
