I simulated circuit which consist of a trans impedance amplifier ,some multistage amplifiers and filters.In my first circuit TIA used is AD8067 and for other parts I used TL074 op amp from TI.This circuit was working perfectly in LT spice. After this I replaced TL074 with OPA1664 and TIA remains the same.But for this circuit I am getting an error as shown below.
Singular matrix: Check nodes d:u3:u2:1#int1 and u1:13 Iteration No. 2 Fatal Error: Singular matrix: check nodes d:u3:u2:1#int1 and u1:13 Iteration No. 2
Circuit diagram and screen shot of error file are attached along with this mail. enter image description here
I connected a 1GIG Resistance from non inverting point to ground.But the problem still exists.
I am attaching the circuit files along with this mail.Circuit 1.Its op is connected to ip of circuit 2.Circuit 2 its op is connected to ip of circuit 3![][1]
I connected a 1GIG Resistance from non inverting point to ground.But the problem still exists. I am attaching the circuit files along with this mail.Circuit 1.Its op is connected to ip of circuit 2.Circuit 2 its op is connected to ip of circuit 3![][1]
  • \$\begingroup\$ Your circuit diagram is not readable. Can you read it ? \$\endgroup\$ – efox29 May 18 '15 at 7:29
"Singular Matrix" issues are usually resolved by adding a 1GIG resistor to ground. It means "a current is too small to calculate." Try adding one from net d:u3:u2:1 to ground. (I can't read it either.)
| improve this answer | |
  • \$\begingroup\$ LTSpice is funny about "1GIG." It must be typed as "1GIG", not "1G". Try that. \$\endgroup\$ – rdtsc Sep 10 '15 at 0:11
