I am doing PSpice CAD by simple schematic generation(not using netlist), I need to apply coupling and for this I need Coupling Component, but I do not know how to use that in schematic, I mean in netlist we have K L1 L2 but when I try to do that directly in CAD I get "Part L1 has no L1 property" "Part L2 has no L1 property" can somebody please tell me the real way to use this component directly through schematic (not using netlist)?
\$\begingroup\$ What do you mean when you say this: "in netlist we have K L1 L2"? \$\endgroup\$– Andy akaCommented May 18, 2015 at 9:28
\$\begingroup\$ Some thing got missing I mean to say in net list we write K(name) L(1st inductor name) L(2nd inductor name) coupling value \$\endgroup\$– UserhanuCommented May 18, 2015 at 9:31
\$\begingroup\$ If it's anything like microcap then component "k" can be found - you need to search for this. In microcap it's located under something like "analogue primitives" from memory. \$\endgroup\$– Andy akaCommented May 18, 2015 at 9:35
\$\begingroup\$ I think I got my problem, when I right click on component and go to the edit properties I can not enter values in L1 and L2 for coupling, is there something that I can do ? \$\endgroup\$– UserhanuCommented May 18, 2015 at 9:56
\$\begingroup\$ Coupling is a number between 0 and 1 where 1 represents total coupling and 0 represents 0 magnetic coupling. L1 L2 needs to be enetered in a different place. \$\endgroup\$– Andy akaCommented May 18, 2015 at 10:08
Show 3 more comments
1 Answer
The problem that I encountered was not a technical one but one that is more of a layout based
we need to change in this Property window at the given location, I do not know the reason but that is what worked for me :)
