8
I upgraded to Eagle 7 a couple of days ago the the scroll behaviour seems to have changed. Using a two finger scroll on a mac trackpad I used to be able to pan around in Eagle 6 but using Eagle 7 this has now become zoom in and out.
Has anyone else experienced a change like this or does anyone know how to revert the behaviour?
    \$\begingroup\$ I would think Eagle has a support page or forums which would be a more appropriate/faster way of getting your answer... \$\endgroup\$ – I. Wolfe May 18 '15 at 14:47
  • \$\begingroup\$ Perhaps, I followed previous similar questions which led me here and I didn't fancy registering on another site so I tried my luck. I switched back to version 6 which has solved my problem for now. \$\endgroup\$ – ArthurGuy May 18 '15 at 18:46
  • \$\begingroup\$ How did you manage to get a version 7 license a couple of days ago? \$\endgroup\$ – Olin Lathrop Apr 21 '17 at 15:01
6
Had the same problem. Fortunately, it's an easy fix!
Options > User Interface...
  1. Set mouse wheel zoom to 0.
  2. Turn Legacy mouse wheel mode off.
Enjoy!
  • \$\begingroup\$ you awesome !!! \$\endgroup\$ – b-ak Oct 5 '17 at 12:07
The solution for me on Eagle 7.6.0 on Macbook was typing SET Interface.UseCtrlForPanning 1 into the command field (near the top of the window). The command key along with trackpad click-and-drag now pans. I found this solution here.
My symptoms were the scrollbars were missing and nothing would pan the window. Two-finger pinch would zoom in and out, but no panning.
