-2
I really need to I2C interface my FPGA with some slave device. I figured I could use the audio codec in my FPGA as a slave.I have gone through some codes from the internet for I2C. But I do not get them.
To initiate a start sequence, What do I do? I know I want to drive SDL low while SCL is high. But I do not have much idea how I should code.
process(Start)
begin
if Start='0' then
   ACTIVE='0';
else
   SCL='1';
   SDL='1';
   SDL='0';
   ACTIVE='1';
end if;
end process;
Is this the way,my start sequence initiation should be? Should I add anything else?
Besides more importantly, How am I supposed to wait for an acknowledgement?
    \$\begingroup\$ I hope this comment is not considered rude, but I think you should first learn how VHDL works and how it can be used to describe hardware. So you can take a class that teaches HDL 'programming' or read a book/tutorial. If you have solved to describe simple structures like counters, FSMs or decoders in hardware, you can try to describe more advanced modules for bus protocols like your requested I²C. Besides that, OpenCores has free I²C cores ready for use. \$\endgroup\$
    – Paebbels
    Commented May 18, 2015 at 20:58
in addition to what was said before, you can found I2C specification help on this: http://i2c.info/i2c-bus-specification and VHDL on https://www.eewiki.net/display/LOGIC/I2C+Master+(VHDL) . But take note that I2C can be customized to read/write different bytes and also with other features like clock stretching and oversampling clock so is better to write your code by yourself.
