I have some query about the priority of if else in verilog. For example.
  If (a)
  b
  else if c
  d
  else if e
  f
  else
  g
At here, those a,b,c...g are all searched ? How do those have priorities in if~else in verilog?
    \$\begingroup\$ What do you mean by 'searched'? There's no precedence, or at least it depends on what b,d,f,g are. \$\endgroup\$ May 19, 2015 at 8:25
  • \$\begingroup\$ @Vladmir Cravero How does it synthesis? \$\endgroup\$
    – gmotree
    May 19, 2015 at 8:38
  • \$\begingroup\$ They're all synthesised, provided a/c/e aren't compile-time constants. \$\endgroup\$
    – pjc50
    May 19, 2015 at 8:46
  • \$\begingroup\$ @ pjc50 I meant as gate. \$\endgroup\$
    – gmotree
    May 19, 2015 at 9:03
  • \$\begingroup\$ Well. I beg to differ. AFAIK (and pls correct me if I'm wrong), if else construct infers a 'Priority routing Network', with the outermost if carrying highest priority. All of it is synthesized using a ladder of multiplexers (2:1 Mux I believe). \$\endgroup\$ May 19, 2015 at 9:46
An if-else construct infers a priority routing network. Following example is taken directly from a verilog book :
if
 (m==n)
r = a + b + c ;
else if (m > n )
r = a - b ;
else
r = c + 1 ;
The circuit is as shown :
As you can see, the outermost if is given a priority in the sense that it is routed first if a match is found, bypassing others.
Ref : Fpga prototyping by verilog
    \$\begingroup\$ Thanks . There are priorities in there as cuicuit. First m and n equality check then m and n size check. \$\endgroup\$
    – gmotree
    May 19, 2015 at 10:17
  • \$\begingroup\$ Yes. And finally a default case when none of the above exists. \$\endgroup\$ May 19, 2015 at 10:21
  • \$\begingroup\$ Mind giving a reference to the book? \$\endgroup\$
    – Dzarda
    May 19, 2015 at 10:25
  • \$\begingroup\$ Added the link to the book. \$\endgroup\$ May 19, 2015 at 10:29
  • \$\begingroup\$ Should the synthesis tool recognize the three cases as mutually exclusive and be able to do one parallell mux? \$\endgroup\$
    – Moberg
    Dec 3, 2019 at 22:19
