I'm building a circuit driven by an Arduino UNO that controls a AY-3-8910 programmable sound generator.
The AY has three pins labeled Channel A, B and C. Each output is an independent sound channel.
I am piping the audio through an LM386 which then drives a small PC speaker.
When I run a single channel, it sounds pretty good. But each time I mix another channel, things start getting really distorted.
I've built this on a breadboard in the past and it sounded great so I don't know what I'm doing wrong this time.
Below is a crude schematic of my circuit. I didn't draw the LM386 because it's the same with or without it and I never used it before.
Any ideas how I can cleanly mix these signals? I don't remember doing anything in the past other than literally connecting all three channels together.
I can provide more schematics and/or videos or pictures too. This is driving me nuts. So I'm hoping someone out there has worked with this sound generator in the past that can provide some insight.
Thanks.
    \$\begingroup\$ The LM386 has differential inputs, how are you hooking it up to the single ended AY-3-8912? Also, the LM386 has some intrinsic gain, you are probably exceeding its rails (the AY-3-8912 outputs a 1V PP square on each channel...) \$\endgroup\$
    – Zuofu
    May 20, 2015 at 0:24
Typical circuit diagram from the manual shows a 1K resistor to ground and capacitive coupling. Both are necessary. The 10K may also be required.
    \$\begingroup\$ I'm an idiot. I totally missed that even after scanning the AY datasheet. Ugh. Rookie mistake. Now it sounds great! Thanks. \$\endgroup\$
    – cbmeeks
    May 20, 2015 at 0:45
