While using a wireless mouse having alkaline batteries, does it matter to the life of batteries, at what distance from my computer I use it? I mean, if I use the wireless mouse from a far distance (within transmitter-receiver's recognisable range) will it drain the batteries more?
closed as off-topic by Nick Alexeev May 20 '15 at 2:52
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions on the use of electronic devices are off-topic as this site is intended specifically for questions on electronics design." – Nick Alexeev
If this question can be reworded to fit the rules in the help center, please edit the question.
It won't drain the batteries any quicker. Your mouse doesn't know how far it is from the receiver plugged in your computer.
  • \$\begingroup\$ That's not necessarily true in a practical sense. If there's a reliable communication protocol such that unacknowledged messages are retransmitted until acknowledged or some give-up threshold, then being at marginal range would result in a lot more transmissions, and that will have an energy cost. Many of these chipsets actually do measure RSSI. On the other hand, if the mouse just keeps blindly transmitting and hoping someone is listening, then it doesn't matter. \$\endgroup\$ – Chris Stratton May 20 '15 at 5:37
  • \$\begingroup\$ +1 For a bluetooth mouse, yes, but I haven't seen one of these for ages. For a standard 2.4GHz wireless mouse (with a USB receiver), there is only one-way communication between the mouse and the receiver on the PC. \$\endgroup\$ – DaveBoltman May 21 '15 at 10:04
