I have a PIC16LF1709 20-pin 8-bit microchip MCU. I am programming it using a PICkit 3. I am able to successfully burn a program to the chip and run it, but it always seems to reset part-way through execution.
While programming the PIC, I'm letting the programmer supply the power, but I can also unplug the programmer and run the chip on its own 5V supply. As recommended, I've run a 50kOhm pull-up resistor from MCLR to Vdd to prevent that from resetting the device.
I have five LEDs connected to RC0-RC4, and I've written the test program below to demonstrate the problems I'm experiencing:
#include <xc.h> /* XC8 General Include File */
#include <pic16lf1709.h> /* Definitions of I/O pins */
void main(void) {
TRISC = 0x0; // port C (all are LEDs or NC) is output
PORTC = 0x0; // turn on all LEDs
for(int i=0; i<500; i++) _delay(250); // delay for about a second
PORTC = 0xFF; // turn off all LEDs
while(1) {
// do nothing, forever
// lights should remain OFF.
I expect the lights to turn on briefly, then turn off and stay off until I power-cycle the device. Instead, the lights are blinking. This makes me think that the PIC is being reset about every 1 - 2 seconds.
I've tried including the following configuration line (other than this, I didn't specify any configuration) in an attempt to disable some of the features that might automatically reset the device. The behaviour was unchanged.
#pragma config MCLRE = OFF, STVREN = OFF, LPBOR = OFF
I've also tried letting the execution run while powered by the 3.25v supplied by the PICkit (as opposed to the 5v supplied by my main power supply), but that made no apparent difference either.
What could be causing this behaviour?
WDT = OFF
. OrWDTE
... \$\endgroup\$ – Eugene Sh. May 20 '15 at 21:21
