Using an ATmega328p, I'm running into a problem when I make an interrupt (INT0 or INT1) active, the code will execute just fine (MusicOnLed and FadeOnLed functions will execute), however as soon as I deactivate the interrupt, the program will do nothing until another interrupt is active.
The global volatile display_select is being changed, as it allows those functions to run, but only when the interrupt is active. When the interrupt is deactivated, either display_select is being changed back to 0xFF, or it is hanging up somewhere.
Ideally, the interrupt fires, changes the display_select value, then goes back to main. In main it evaluates display_select, and sees that it is changed (per the interrupt changing it), and keeps executing that loop.
This was done this way to get out of having to use nested interrupts, as I was running into issues with those.
#define F_CPU 16000000L
#include <avr/io.h>
#include <stdio.h>
#include <util/delay.h>
#include <avr/interrupt.h>
#include "ADC.c"
#include "serial.c"                 //only needs to be included if using stdio or serial functions
//Preprocessor Macros
#define EQ_RESET 6                  //msgeq-7 reset on portd bit 6
#define STROBE 5                    //strobe pin on portd bit 5
#define SW0 2                       //SW0 on PORTD bit 2 (INT0)
#define SW1 3                       //SW1 on PORTD bit 3 (INT1)
#define SW2 4                       //SW2 on PORTD bit 4 (PCINT20)
#define GREEN OCR1A                 //GREEN LED is PWM Output Compare A for timer1
#define RED OCR1B                   //RED LED is PWM Output Compare B for timer1
#define BLUE OCR2A                  //BLUE LED is PWM Output Compare A for timer2
//Global audioband array
uint8_t AudioLevel[7] = {0};        //init 7 position AudioLevels array to 0
//Globals for storing average output values
uint8_t out_low;
uint8_t out_mid;
uint8_t out_high;
//Fade delay function declaration
const int led_delay = 50;
//Selector switch global initialized at 0xFF
volatile uint8_t display_select = 0xFF;
//Function Prototypes
void GetAudioBandLevel(void);                           //Gets audio levels, stores in global AudioLevels array
void MusicOnLed(void);                                  //Music display function on LEDs
void FadeOnLed(void);                                   //Fade display function on LEDs
void StrobeOnLed(uint8_t, uint8_t, uint8_t);            //Strobe display function on LEDs
void IncrementUp(uint8_t, uint8_t);                     //Increments specific LED up by specified delay cycle time (const int led_delay)
void IncrementDown(uint8_t, uint8_t);                   //Increments specific LED down by specified delay cycle time (const int led_delay)
void Init_Timer1_PWM(void);                             //Timer1 for PWM on BASS and MID
void Init_Timer2_PWM(void);                             //Timer2 for PWM on TREBLE
void Init_IO(void);                                     //See actual function for IO Port Description
void SolidColorOnLed(void);                             //Changes between colors on LED
int main(void)
    init_ADC();                     //init ADC for channel 0, 8 bit resolution, ADC clock = clk/128
    Init_Timer1_PWM();              //timer1 and 2 as 8 bit output compares
    Init_Timer2_PWM();
    Init_IO();                      //enables things and interrupts
    sei();                          //enables global interrupts
    while(1)
        while(display_select == 0xFF)
            //do nothing while waiting for an interrupt
        while(display_select == 0x00)
            MusicOnLed();
        while(display_select == 0x01)
            FadeOnLed();
void IncrementUp(uint8_t led, uint8_t max_val)
    uint8_t i = 0;      //LCV
    for(i = 0; i < max_val; i++)
        switch(led)
            case 1:
                RED     = i;
            break;
            case 2:
                GREEN   = i;
            break;
            case 3:
                BLUE    = i;
            break;
        _delay_ms(led_delay);
void IncrementDown(uint8_t led, uint8_t max_val)
    uint8_t i;      //LCV
        switch(led)
            case 1:
            RED     = max_val - i;
            break;
            case 2:
            GREEN   = max_val - i;
            break;
            case 3:
            BLUE    = max_val - i;
            break;
    uint8_t audio_band = 0;
    DDRD    |=  (1 << STROBE)|(1 << EQ_RESET);              //PORTD bit strobe and reset pins output
    PORTD   &=  ~((1 << STROBE)|(1 << EQ_RESET));           //sets strobe and reset low
    PORTD   |=  (1 << EQ_RESET);                            //reset goes high
    _delay_us(100);                                         //delay 100usec for setup time req
    PORTD   |=  (1 << STROBE);                              //strobe goes high
    _delay_us(50);                                          //strobe delays
    PORTD   &=  ~(1 << STROBE);                             //strobe goes low
    PORTD   &=  ~(1 << EQ_RESET);                           //reset reset
    _delay_us(50);
    for(audio_band = 0; audio_band < 7; audio_band++)
        PORTD   &=  ~(1 << STROBE);             //resets (set strobe pin low (active))
        _delay_us(30);                          //setup time for capture
        AudioLevel[audio_band] = read_ADC();    //reads 8 bit resolution audio level from audio bandpass filter
        PORTD   |=  (1 << STROBE);                  //sets (set strobe pin high again)
        _delay_us(50);                          //not sure if needed - check datasheet
    GetAudioBandLevel();
    out_low     = (AudioLevel[0] + AudioLevel[1]) / 2;                      // Average of two Lowest Bands
    out_mid     = (AudioLevel[2] + AudioLevel [3] + AudioLevel[4]) / 3;     // Average of three Middle Bands
    out_high    = (AudioLevel[5] + AudioLevel[6]) / 2;                      // Average of two Highest Bands
    uint8_t led_out_low     =   out_low * 1.2;
    uint8_t led_out_mid     =   out_mid * 1.2;
    uint8_t led_out_high    =   out_high * 1.2;
    if(out_low >= 212)
        led_out_low = 255;      //set to max brightness if overflow condition would otherwise occur
    if(out_mid >= 212)
        led_out_mid = 255;      //set to max brightness if overflow condition would otherwise occur
    if(out_high >= 212)
        led_out_high = 255;     //set to max brightness if overflow condition would otherwise occur
    //assign to outputs
    GREEN   = led_out_low;
    RED     = led_out_mid;
    BLUE    = led_out_high;
    //_delay_ms(10);            //old delay before menu implementation
    _delay_ms(1);
void Init_IO(void)
    DDRB = 0x3F;                                            //portb as output
    DDRD    &= ~(1 << SW0) | ~(1 << SW1) | ~(1 << SW2);     //portd bits 2, 3, and 4 as inputs (pushbuttons)
    PORTD   |= (1 << SW0) | (1 << SW1) | (1 << SW2);        //turn pullups on only on pushbutton input pins
    EICRA   = 0x0;                                          //Enables active LOW triggering on ext. interrupts on INT0 and INT1 pins (SW0 and SW1)
    EIMSK   = 0x3;                                          //Enables external interrupts on INT0 and INT1 (SW0 and SW1)
    PCMSK2  = 0x10;                                         //Enable interrupts on PCINT20 (SW2)
    PCICR   |= (1 << 2);                                    //Enables interrupts on pin change request 2 reg
    DDRC    = 0x00;                                         //port c as input
    PORTC   = 0x3F;                                         //pullups on
    TCCR1A = 0b10100001;        // Timer1 in fast mode PWM
    TCCR1B = 0b00000100;        //
    TIMSK1 = 0b00000110;
    TCCR2A = 0b10100001;        // Timer2 in fast mode PWM
    TCCR2B = 0b00000110;        //
    TIMSK2 = 0b00000100;
    GREEN   = 0;
    BLUE    = 0;
    RED     = 90;
    //see led_delay for led delay time
    //RED is defined as 1, GREEN as 2, BLUE as 3 when passing values to function
    while (1)
        IncrementUp(2, 90);
        IncrementDown(1, 90);
        IncrementUp(3, 90);
        IncrementUp(1, 90);
        IncrementDown(2, 90);
        IncrementDown(3, 90);
        IncrementUp(1, 90);
        IncrementUp(2, 90);
void StrobeOnLed(uint8_t red, uint8_t green, uint8_t blue)
    RED     = red;
    GREEN   = green;
    BLUE    = blue;
    _delay_ms(100);
    RED = 0;
    GREEN = 100;
    BLUE = 0;
ISR(INT0_vect)
    display_select = 0x00;
ISR(INT1_vect)
    display_select = 0x01;
ISR(PCINT2_vect)        //PCINT20
    display_select++;
EDIT:
I modified main() to:
int main(void)
    Init_Timer2_PWM();
    while(1)
        switch(display_select)
            case 0x00:
                    MusicOnLed();
                break;
            case 0x01:
                    //FadeOnLed();
                break;
            case 0xFF:
                    RED = 0;
                    GREEN = 50;
                    BLUE = 0;
                break;
What is happening is when INT0 stays in the low state (triggered), MusicOnLed() keeps functioning as long as INT0 is in the low state. As soon as INT0 goes from low to high (triggered to not triggered), display_select should still be 0x00 (allowing MusicOnLed() to keep running) but is somehow being reset to 0xFF. This obviously causes the GREEN LEDs to become lit, and the other LEDs to turn off.
EDIT 2
I've changed the code around to poll the display_select variable during the execution of both FadeOnLed() and MusicOnLed() functions. I am able to now interrupt the functions.
I have also changed the DDRD and PORTD values around to reflect what I have learned online
My new issue is that INT1 always seems to be active. In the simulator, PIND bits 2 and 4 get set, while the others remain reset. I am wondering if this causes INT1 to fire continuously (being a level interrupt).
Please see the following following changed functions:
int main(void)
    Init_Timer2_PWM();
    while(1)
            case 0x00:
                    while (display_select == 0x00)
                        MusicOnLed();
                break;
            case 0x01:
                    FadeOnLed();
                break;
            case 0xFF:          //standby glow faint purple
                RED = 1;
                GREEN = 0;
                BLUE = 1;
            break;
    while((i < max_val) & (display_select == 0x01))
        switch(led)
            case 1:
            RED     = i;
            break;
            case 2:
            GREEN   = i;
            break;
            case 3:
            BLUE    = i;
            break;
        i++;
        switch(led)
            case 1:
            RED     = max_val - i;
            break;
            case 2:
            break;
            case 3:
            BLUE    = max_val - i;
            break;
        i++;
void Init_IO(void)
    SMCR |= (1 << SM0);                                     //Sets sleep mode 'ADC Noise Reduction'
    //DDRD  &= ~(1 << SW0) | ~(1 << SW1) | ~(1 << SW2);     //portd bits 2, 3, and 4 as inputs (pushbuttons)
    DDRD    |= (1 << SW0) | (1 << SW1) | (1 << SW2);        //ddrd set high
    EIMSK   |= (1 << INT1) | (1 << INT0);                   //Enables external interrupts on INT0 and INT1 (SW0 and SW1)
    //PCMSK2    = 0x10;                                         //Enable interrupts on PCINT20 (SW2)
    //PCICR |= (1 << 2);                                    //Enables interrupts on pin change request 2 reg
  • \$\begingroup\$ I'm not entirely clear on what you expect to happen, I should think the FadeOnLED ought to get locked up in an infinite loop (possibly up to the next watchdog reset) and MusicOnLED to continue executing once set. Regardless this seems a golden opportunity to get your debugger set up, your ATmega328 ought to have a debugWire interface suitable for an AVR Dragon or the like. \$\endgroup\$
    – doynax
    May 19, 2015 at 21:57
  • \$\begingroup\$ FadeOnLED should get locked in an infinite loop as soon as SW1 (INT1) is activated. That loop should be interruptable by SW0 (INT0) going active, and call MusicOnLed. I've got an STK600 and I'll work on getting JTAG setup for the 328. \$\endgroup\$
    – Seedy_Seltzer
    May 19, 2015 at 22:03
  • \$\begingroup\$ I see no obvious problem with your logic in general. However, FadeOnLed() would never return due to the while(1) loop in there. That is probably not what you intended. \$\endgroup\$
    – Rev
    May 20, 2015 at 6:28
  • \$\begingroup\$ I think the while(1) in the function FadeOnLed() should control the state of the variable display_select, otherwise your code, when enter in the function, there remains!!! \$\endgroup\$ May 20, 2015 at 10:16
  • \$\begingroup\$ Is it possible that your device gets reset? \$\endgroup\$
    – helleye
    May 20, 2015 at 14:41
There is an infinite loop inside FadeOnLED(). Once INT1 is triggered, it will take your main() inside FadeOnLED() and as it contains while(1) there is no way out of it. So your main program flow will be stuck inside the infinite loop of FadeOnLED(). After that, other interrupts can shorty interrupt the work of this infinite loop(where your main program flow is), but will not get out (break) of it.
One possible solution (not very nice, but just to show the idea) is to use the following:
    GREEN   = 0;
    BLUE    = 0;
    RED     = 90;
    while (display_select == 0x01)
  • \$\begingroup\$ The problem isn't that the FadeOnLed() executes infinitely (although I can see what you mean), its that display_select is being reset to 0xFF after an interrupt modifies that value. \$\endgroup\$
    – Seedy_Seltzer
    May 20, 2015 at 14:04
  • \$\begingroup\$ See my edit to the original post - I hope I clarified the issue better \$\endgroup\$
    – Seedy_Seltzer
    May 20, 2015 at 14:29
