I have nearly non previous experience with VHDL and the most of the code here is given to me by the teacher.
I'm trying to communicate with a ADXL362 accelerometer using SPI on a Xilinx Sparten 3E. As far as I can understand from the RTL schematic of the ADXL362 I need to make a module with 5(?) ports. MISO, MOSI, SS(slave select), data ready and system clock for the top module to talk with it.
The SPI interface behaves like a submodule of the ADXL362 module, so how much to I need to declare of the ports in my top module then?
By the looks of it, the ADXL is the slave and I have to write a master module to be able to talk with it. But all the examples I have seen just got a lot more wires then what I got in the premade code. So I'm totally stuck as of now, so any help would be greatly appreciated.
Top modlue code:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity top_module is
port(
sysclk :in std_logic;
--uart_tx: out std_logic;
btn : in STD_LOGIC_VECTOR (3 downto 0);
--miso : in STD_LOGIC;
tx : out std_logic;
led1 : out std_logic;
led2 : out std_logic
end top_module;
architecture Behavioral of top_module is
signal tempX : std_logic_vector (11 downto 0);
signal tempY : std_logic_vector (11 downto 0);
signal tempZ : std_logic_vector (11 downto 0);
signal ZZ : std_logic_vector (7 downto 0);
signal YY : std_logic_vector (7 downto 0);
signal XX : std_logic_vector (7 downto 0);
signal clr: std_logic;
component ADXL362Ctrl
port
SYSCLK : in STD_LOGIC; -- System Clock
RESET : in STD_LOGIC;
-- Accelerometer data signals
ACCEL_X : out STD_LOGIC_VECTOR (11 downto 0);
ACCEL_Y : out STD_LOGIC_VECTOR (11 downto 0);
ACCEL_Z : out STD_LOGIC_VECTOR (11 downto 0);
--SPI Interface Signals
SCLK : out STD_LOGIC;
MOSI : out STD_LOGIC;
MISO : in STD_LOGIC;
SS : out STD_LOGIC
end component;
end component;
-- convert data from 12 to 8 bit
component convertion is
port (
ACCEL_X : in STD_LOGIC_VECTOR (11 downto 0);
ACCEL_Y : in STD_LOGIC_VECTOR (11 downto 0);
ACCEL_Z : in STD_LOGIC_VECTOR (11 downto 0);
Ax : out std_logic_vector (7 downto 0);
Ay : out std_logic_vector (7 downto 0);
Az : out std_logic_vector (7 downto 0)
end component;
begin
A : ADXL362Ctrl
--clr <= btn(3);
port map
MISO => miso,
SYSCLK => sysclk,
RESET => btn(3),
ACCEL_X => tempX,
ACCEL_Y => tempY,
ACCEL_Z => tempZ,
SCLK => sclk,
MOSI => mosi,
MISO => miso,
SS => ss
A3: convertion
port map
Ay => YY,
Az => ZZ,
Ax => XX,
ACCEL_X => tempX,
ACCEL_Y => tempY,
ACCEL_Z => tempZ
SPI interface http://pastebin.com/t7LFnvDp ADXL code http://pastebin.com/uwZ8mZBH
