I am trying to mod my arcade stick so I can switch two commonly swapped buttons on the controller.
Essentially they are simple 2 terminal momentary switches connected directly to the controller PCB. I would like to switch their responsibilities, so in my case the Back button and the LB button on the XBox pcb I would like to swap so the Back actuates the LB button on the PCB and the LB actuates the Back button.
My assumption is that I would need a switch with 8 terminals, 4 in 4 out.
What type of switch am I looking for?
If the two existing buttons do not share a common GND connection then you will need a four pole double pole (4PDT) toggle switch. Such switch has twelve terminals.
If the two existing buttons share a common GND then you can get by with a double pole double throw (DPDT) switch. That switch will have six terminals.
Here is how you would connect the button flipper switch when a common GND is in place.
If the two switches do not share a common GND then you would use the 4PDT switch and basically duplicate the above circuit on the switch for the other sides of each button.
|improve this answer|||||
  • \$\begingroup\$ I am actually unsure whether they share a common ground. The PCB is housed in a closed off compartment so I'll see if I can open that and check the GND. Thanks for the quick response! \$\endgroup\$ – Tom 'Blue' Piddock May 22 '15 at 10:47
  • \$\begingroup\$ If you have easy access to the two push button's terminals then it is easy to check for a common connection between them using a multimeter on the OHMS scale or the CONTINUITY test scale. \$\endgroup\$ – Michael Karas May 22 '15 at 11:01
