AFAIK each of the world leading cordless power tools manufacturers produces several "product lines" of cordless power tools with different voltages. For example, Bosch currently produces tools with Li-Ion batteries with 10,7V, 14,4V, 18V and 36V output and the higher the voltage the more powerful a tool is.
Now those tools are powered by batteries that are assembled from cells with lower voltage (something like 3,7 volts for Li-Ion cells I guess) and cells are connected in sequence until the target voltage is reached.
They could instead connect cells in parallel. They would have the same voltage, but higher current and that would again yield higher power.
Why do they choose higher voltage over same voltage and higher current to get higher power in electric tools?
