Arduino pins can be used as UART using the library SoftwareSerial.h Is there any alternative for AVR?
I need more than one serial port on a ATmega328P, but i don't use arduino.
SoftwareSerial.h is tied to Arduino.h and Arduino pins. I do not use Arduino, i use avr-gcc with atmega328p and atmega8.
  • \$\begingroup\$ Sorry my english. \$\endgroup\$
    – Avelino
    May 24, 2015 at 0:02
  • \$\begingroup\$ Sorry, as much as I would like to understand the question, I can't. \$\endgroup\$ May 24, 2015 at 0:03
  • \$\begingroup\$ I need more than one serial port on a ATmega328P \$\endgroup\$
    – Avelino
    May 24, 2015 at 0:04
  • \$\begingroup\$ Arduino is AVR. Port it over. \$\endgroup\$
    – Matt Young
  • \$\begingroup\$ @Avelino Transmit only, or receive only, or both? What baud rate? \$\endgroup\$ May 24, 2015 at 0:05
AVR274 describes a single-wire, half-duplex software UART.
AVR304 describes a half-duplex, interrupt-driven software UART, and AVR305 describes a polled alternative.
AVR307 describes implementing a half-duplex UART using a USI.
All code associated with each app note can be downloaded from Atmel's Microchip's website.
    \$\begingroup\$ I would strongly recommend using the interupt driven software UART. The polled alternative frequently results in corruption, even when just using as simplex output. \$\endgroup\$
    – teambob
    May 24, 2015 at 6:33
