For a common base configuration BJT such as the one shown here: enter image description here
How can I derive the voltage gain and current gain?
Forgive me for using another schematic for common base configuration, but I found it more understandable in education purpose. Common base small signal analysis
First, voltage gain:\$A_{v}=\frac{u_{iz}}{u_{ul}}\$
Usual way to deal with this fraction is to derive the expression for both of the voltages separately and then evaluate.
Output voltage is equal to: \$u_{iz}= -h_{fe}\cdot i_b \cdot R_c ||R_T\$
Input voltage is equal to: \$u_{ul}=i_{ul}\cdot R_E = -i_b \cdot r_{be}\$. Notice the sign of the current and why we took \$-i_b\$(because the current flows in the negative terminal of the predefined voltage \$u_{ul}\$)
Therefore, voltage gain is equal to: \$A_{v}=\frac{u_{iz}}{u_{ul}}=\frac{-h_{fe}\cdot i_b \cdot R_C||R_T}{-i_b \cdot R_E}=h_{fe}\frac{R_C||R_T}{R_E}\$
Current gain is a bit difficult to derive, but don't give up :)
First, we need to see what is the expression for input resistance of the amplifier \$R_{ul}\$ (which is also an important parameter while designing an amplifier)
Input resistance is: \$R_{ul}=\frac{u_{ul}}{i_{ul}}\$
Currents are: \$i_{ul}=i_{Re}+i_e; i_{Re} = \frac{u_{ul}}{R_E}; i_b = - \frac{u_{ul}}{r_{be}}\$
If we apply KCL for node E we have: \$i_e+i_b+h_{fe}i_b=0, i_e=-i_b(1+h_{fe})\$
Expression for input current is: \$i_{ul}=i_{Re}+i_e=i_{Re}-i_b(1+h_{fe})=\frac{u_{ul}}{R_E}-(1+h_{fe})=u_{ul}\cdot (\frac{1}{R_E}+\frac{1}{\frac{r_{be}}{1+h_{fe}}})\$
Now when we take a step back and take a look at the input resistance expression: \$R_{ul}=\frac{u_{ul}}{i_{ul}}=R_E || (\frac{r_{be}}{1+h_{fe}})\$
From the last expression we can notice that the input resistance is equal to 2 resistor in parallel. First one is \$R_E\$ and the second one we can call \$R_{ul}'\$.
We are finally here, \$i_{iz}=\frac{u_{iz}}{R_T}; i_{ul}=\frac{u_{ul}}{R_E || R_{ul}'}\$
Current gain: \$A_{i}=\frac{i_{iz}}{i_{ul}}=\frac{\frac{u_{iz}}{R_T}}{\frac{u_{ul}}{R_E || R_{ul}'}}=\frac{u_{iz}}{u_{ul}} \cdot \frac{R_E || R_{ul}'}{R_T} = A_V \cdot \frac{R_E ||R_{ul}'}{R_T}\$
From here we can see that the current gain of these configuration can never be bigger than 1 and always positive.
I hope everything is clear now!
| improve this answer | |
