I've got a PICKit 2 with a PIC16F690 chip plugged in, and installed MPLAB and made a sample program in C, which compiles fine. However, there's only the option to "Program to target device", "Read from target device", or some other options to erase memory, all of which work fine, but I can't work out how to actually make the program run on the chip. MPLAB says I can't debug the chip:
"PK2Error0028: Unable to enter debug mode"
"NOTE: This device requires an ICD Header for debug. See "Header Specification" DS51292."
After some research, apparently I need a different interface board to debug it.
When debugging, the option to run the program comes up, but when set to "Release" mode, it only gives the option to read/write/erase from the board. How can I run it?
The code is as follows:
#include <htc.h>
#include <stdio.h>
#include <stdlib.h>
int main(int argc, char** argv) {
return (EXIT_SUCCESS);
Which doesn't actually do anything yet
