I try to communicate with EPPROM using SPI. the image illustrate the read status register sequence.
the program I'm using checks the receive data register each time SPI finish sending (send data register empty).
my question is, did SPI master receives data on MISO when he send the instruction data as shown in image below. and in general did SPI always receive data on MISO in same time he send data on MOSI?
in other words, to get status register out data, should I send other NULL data (0x00)??
    \$\begingroup\$ For the specific case of the timing diagram that you show in your question it looks like to get the status out you simply send the instruction equal to 00000101. The "D" pin thereafter shows that the output data could be 1 or 0 and that as long as the C toggles with the S pin low the status register output will continue to come out each eight clocks. \$\endgroup\$ – Michael Karas May 27 '15 at 13:34
The general concept of SPI is that it can send and receive bits at each clock time. That said every SPI device will work differently with regard to what bits are used in each path. It is up to you to read the DATASHEET for your device to figure out what bits required are on the MOSI side to get the device to do what you want and provide back what you need on the MISO side.
|improve this answer|||||
  • \$\begingroup\$ in fact im using company function (should not modify). there is one function used : transmit series of data and then set CS high. each time transmit finish (data register empty), we check receive register for data. in this case you think I should transmit some 0x00 after transmitting the instruction in order to get the result in receive register?? \$\endgroup\$ – mikmik May 27 '15 at 13:41
    \$\begingroup\$ You "company function" may or may not be up to the demands of what your SPI device requires to operate. You have provided far too little information to allow us to get it working for you. As I said before you have to look at the data sheet. If your "company function" can only send one byte (8 clocks) per call and each call entails an S transition from from H to L and then back to H after the 8th clock time they you will NOT be able to use it as is to read out the status as per the timing diagram you provided. \$\endgroup\$ – Michael Karas May 27 '15 at 13:57
  • \$\begingroup\$ after S is low, this function send a set of one byte (8 clocks) {0x44,0x52,0x21,.....}.then the S is driven high. so what I want to say is that, I should send instruction code, and send another 0x00 in order to keep S low {inscode, 0x00} \$\endgroup\$ – mikmik May 27 '15 at 14:04
  • \$\begingroup\$ Like I said before - Every SPI device will be somewhat different and there is no set guarantee that someone else's "generic" SPI routine is going to be compatible with every single SPI device. It is common practice to have hosts work in 8-bit chunks but that will fail to work with one SPI device I worked with in the past that has a hard requirement of 25 clocks per transaction. That crazy device also had a change of phase between C (SCK) and Q (MISO) between the initial command out part and the data readback portion of the protocol. I had no choice but to design a customized bitbang for it. \$\endgroup\$ – Michael Karas May 27 '15 at 14:04
  • \$\begingroup\$ if for example the SPI used with a an OS with scheduler, and the scheduler interrupt the process in the middle of a byte transfer (4 clock tops only send), then resume. the slave should not care???? \$\endgroup\$ – mikmik May 27 '15 at 20:31
SPI is a full duplex bus. That means that communication in both ways happen simultaneously.
In hardware it may be implemented by 2 shift registers that are clocked by the SPI clock. The transmit register will clock data out, and the receive register will clock data in. Most microcontrollers will access the transmit register on write, and receive register on read.
Both shift registers are clocked with the same clock. So if you want to clock data into the receive register, you need to send a 00h byte. This is often considered "safe" to send.
In the code bases I have worked on, we have typically implemented SpiTxRx routines. It takes a byte to transmit, and also returns the byte read. In my opinion this is good practice, because if you don't read the SPI receive buffer (e.g. you think can optimize by writing a faster SpiTx routine) at all the hardware may flag a buffer overrun and lock up the SPI peripheral in an error state.
SPI data transfer in either direction means the master sends a clock and whoever wants to say something (including the master itself) puts it onto the data line with the clock cycles.
In principle, the master could just generate the clock without sending data out, but this is the same as sending a 0x00.
Some SPI libraries include only one routine, which sends and receives a byte simultaneously. Others have a separate routine to send a byte and ignore the result. Including the latter function in a library may allow performance to be improved significantly (sometimes almost doubled) on some platforms since the transmit-and-ignore-result routine can return as soon as the hardware starts transmitting the byte in question, even though it wouldn't be able to return data until the action finishes. To allow high speed reception, some libraries may offer a "get a byte and start receiving another" function.
I haven't noticed much consistency in how the higher-performance libraries operate, and avoiding data corruption while overlapping operations can be tricky, but the performance improvements that can be obtained by overlapping I/O and computations can be very significant and worth the effort.
