I'm trying to understand if I can get GPS coordinates using only a GPRS/GSM module. Probably I can do it by triangulation using BTS on the terrain and based on the RF signal but is that possible? Where do you think I can get info to guide me in that field?
    \$\begingroup\$ What is BTS? Yes triangulation is possible if you know the mobile phone tower locations. \$\endgroup\$ May 27, 2015 at 17:14
    \$\begingroup\$ BTS is exactly what you referred. When you receive the signal from the BTS is there any field in the frame or something to read their location? Sorry for the generic questions. \$\endgroup\$
    – scuba
    May 27, 2015 at 17:21
  • \$\begingroup\$ I believe you will have to lookup the cell location using it's ID on the internet, if connected to. Like here for example, or using Google API \$\endgroup\$
    – Eugene Sh.
    May 27, 2015 at 17:33
  • \$\begingroup\$ hum ok. Thanks for that. But imagine if we don't know where we are How can we search for an ID? Or do you think that we can find the parameters like the ID, MCC, MNC, Network, LAC, CellID in the frame that we receive from the GPRS data? \$\endgroup\$
    – scuba
    May 27, 2015 at 17:54
    \$\begingroup\$ @scuba Yes, I believe this is the idea. I have no much experience in this kind of stuff, but you can take a look at this thread Specifically the AT+KCELL command \$\endgroup\$
    – Eugene Sh.
    May 27, 2015 at 18:00
There are some cellular providers that have implemented posisioning services on their networks, so you can get the latitude and longitude using some special AT commands. The problem with this option is that is very dificult to get information or support about this feature.
  • \$\begingroup\$ It's not so difficult to get that. Follow this thread. It was provided by @Eugene Sh. \$\endgroup\$
    – scuba
    Jun 3, 2015 at 13:47
  • \$\begingroup\$ Thanks for the info. It's very useful. Also, some cellular providers do these calculations and they offer an AT command, so all you have to do is to execute this AT command in your modem and the network will answer you with your approx. location (lat and long). \$\endgroup\$
    – Dante
    Jun 4, 2015 at 14:40
