Good afternoon fellow students of life,
I have a particular question that relates to the use of a Duracell USB switching power supply as the main supply for a high sensitivity sensor board. Most of the noise is below 3.58MHz going down to 300 kHz.
and has this waveform.
The schematic uses this configuration to try and eliminate the noise by blocking it in the first place. The chip inductors are separate.
A variation on this that I found on the web was to use a decade of capacitors (100uF, 10uF) in front of a ferrite bead with an electrolytic, taltanium, and ceramic (10uF, 47uF, 0.1uF) after.
http://www.ti.com/lit/an/scaa048/scaa048.pdf and http://www.ftdichip.com/Support/Documents/AppNotes/AN_146_USB_Hardware_Design_Guidelines_for_FTDI_ICs.pdf
I know that there is no perfect solution to this problem
Is this a better way of accomplishing noise suppression?
As you can see there is an extra inductor (L3) to decouple the AGND and the DGND.
Thanks ahead of time.
    \$\begingroup\$ You may be restricting answers by addressing this question to "fellow students of life". I don't feel qualified on this basis to provide an answer because at my age I'm more concerned about death. \$\endgroup\$
    Commented May 29, 2015 at 14:14
  • \$\begingroup\$ That's kind of morbid. I was addressing the community as a whole since we should be continuously learning. Even before "death". I would still like to have your comment on the topic of filtering a noisy USB source. Although, like already commented, it is not the ideal source. \$\endgroup\$
    – MiscBob
    Commented May 29, 2015 at 16:14
Using a switch-mode regulator (in the Duracell USB PSU) for "a high sensitivity sensor board" is your problem. Sensitive analog electronics quickly succumbs to the noise inherent with such regulators. You can go to town with filtering (and simply throwing a cap of every type is not the ideal way to go about it), but some still gets through - whether such efforts are enough for your needs can't be gleaned from what you've told us.
It's traditional to add a linear regulator stage between the raw switch-mode PSU and analog circuitry. If your analog circuitry will happily operate at less than 5V, then a LDO (low drop-out voltage) linear reg can be added, but this assumes a lot about the analog circuitry (head-room, voltage reference in an ADC, etc).
  • \$\begingroup\$ There are LDO's later down the line to help with further filtering. Actually there are two in the sensors pathway. The measured sensor is a very low current sensor. The LDO linear regulators are a REF3040 and a REF3020 with a RC filter in between. I was just wondering is there was a better way to accomplish the filtering at the source in a more efficient manner and if it is necessary to have the inductor on the ground path immediately from the USB. Also would a low impedance capacitor in front of the inductors help or cause more harmonics? \$\endgroup\$
    – MiscBob
    Commented May 29, 2015 at 16:11
  • \$\begingroup\$ ok. so do you actually have a problem with this 300kHz (& its harmonics) getting into your analog readings (i'm guessing yes, or you wouldn't be here ;) ? if so then I'd be looking at tuning your LC filtering to target these frequencies, rather than just a scatter-gun approach thus far. \$\endgroup\$ Commented May 30, 2015 at 1:37
    \$\begingroup\$ I added an RC filter in between the regulator and the 5Vusb after the inductor. Seems to work fine. Thank you for your help. \$\endgroup\$
    – MiscBob
    Commented Jun 7, 2015 at 2:45
